Date/Time: Sat, 18 May 2024 07:13:32 +0000
point and figure % still supported ?
View Count: 647
[2018-10-25 23:38:55] |
N!co - Posts: 140 |
Hi, i know the point and figure study is not supported anymore is there now still a way to draw the box reveral based on % move ? thank you very much |
[2018-10-26 01:26:48] |
The Point and Figure study is still supported. We notice that it does not show any chart bars. We are checking on this now. This will be fixed today.
[2018-10-26 02:26:03] |
We have determined the reason for the problem. This was an inadvertent issue when we were correcting another issue reported by a user relating to the high and low values of Point and Figure bars from what we can remember. A new release will be out later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-26 02:26:18
[2018-10-26 02:44:35] |
N!co - Posts: 140 |
thank you !!
[2018-10-26 07:40:54] |
We have released a new revision of 1829. Update with Help >> Download Prerelease to resolve this.
