Date/Time: Sun, 28 Apr 2024 17:23:36 +0000
VWAP Bands
View Count: 1909
[2018-10-25 13:11:59] |
RonW - Posts: 103 |
For the Volume Weighted Average Price study, would it be possible to add another choice to Input 2/Standard Deviation Band Calculation Method? The choice I would add is Percentage, so that the study could for example draw lines 1% above and below VWAP. Thanks, RLW |
[2018-10-25 17:46:46] |
We will see about this.
[2019-10-10 14:55:53] |
User10875 - Posts: 42 |
Hello, any info on that? Thx. |
[2019-10-11 14:08:34] |
Sorry, we have not had a chance to get to this. There has just been a lot going on lately. It is on our list of things to do when we have some spare time.
[2019-11-13 00:01:36] |
We finally had a few minutes to add this option in. In the next Pre-Release (v 2010), you will have a new option for Input Standard Deviation Band Calculation of Percentage. This just takes the percentage of the VWAP at the specific bar and uses that as the offset. So entering a value of 2 would be an offset of 2% of the VWAP. This has been documented here: Volume Weighted Average Price (VWAP) with Standard Deviation Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
