Date/Time: Sat, 18 May 2024 10:42:23 +0000
1 tick data only for specific charts
View Count: 633
[2018-10-25 11:07:12] |
User465507 - Posts: 74 |
Hi, I'm setting up number bars for some specific charts I'm looking at. But I do not want the Sierra Chart default to be 1 tick data intraday for everything it's too much. Is there any way for me to get 1 tick data only on specific charts and 1 second on everything else? The only way I can think around this is just to run another instance of Sierra for the specific charts I want to grab 1 tick data for. |
[2018-10-25 17:45:43] |
Yes you do need to use another instance for this. Refer to: Using DTC Server for Data and Trading in Another Sierra Chart Instance Make sure you use 1 tick data in the main instance though. The sub instance can use a higher setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-25 17:46:33
