Date/Time: Sun, 19 May 2024 02:02:59 +0000
convert .depth data to .csv
View Count: 1316
[2018-10-24 18:33:31] |
User644165 - Posts: 25 |
Hi All, I see that SC can collect level 2 data and store it. Is there a way to somehow convert it to csv so I can do some backtesting? Thank you! |
[2018-10-24 19:05:45] |
No this is not supported. It would take way too much space.
[2018-10-25 06:06:46] |
I was thinking of using the existing .depth files found in the c:\SierraChart\Data\MarketDepthData folder,because I assume it stores depth data. I guess the market depth historical study is using this folder for storig depth data, but please correct me if I am wrong. So I am not talking about recieveing any kind of data from your server, just using the one that is already stored on my PC. I assume not every nanosec is recorded but it would do the job for me.
[2018-10-25 19:10:52] |
Yes the Market Depth Historical Graph study does use the data in that folder. That data cannot be exported and the format is not documented.
