Date/Time: Sat, 18 May 2024 16:54:49 +0000
Rectangle alert appearance change problem
View Count: 574
[2018-10-24 18:12:37] |
User764057 - Posts: 1 |
So, when I open the rectangle drawing alert config and set the color to change when the alert is true,then the color changes, but not the specified one.When I set the same for horizontal line or other,then it is working.Can You help me plz!Thank You!
Képernyőfelvétel (2).png / V - Attached On 2018-10-24 18:10:21 UTC - Size: 94.9 KB - 214 views Képernyőfelvétel (3).png / V - Attached On 2018-10-24 18:10:27 UTC - Size: 93.78 KB - 221 views Attachment Deleted. |
[2018-10-25 21:54:43] |
We found the problem and have fixed it. It will be in the next release. It was using the Extending Rectangle's Configuration Files for the Rectangle alerts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
