Date/Time: Mon, 29 Apr 2024 07:12:21 +0000
Drawing of last bar lags about 2 seconds
View Count: 1219
[2013-10-31 09:00:09] |
altair - Posts: 8 |
Hello, I use IB as data feed. Is it normal that the drawing of the last bar is always lagging about 2 seconds after a price change ? The last price in the price scale is displayed in real time, while the drawing of the bar is always lagging. Is this normal behavior ? Thanks. |
[2013-10-31 09:29:29] |
Yes if you are using True Real-time Data: https://www.sierrachart.com/index.php?l=doc/IB.php#TrueRealTimeData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-31 14:35:17] |
altair - Posts: 8 |
Yes I use True Real-Time Data, and this is one of the major reason I use SC. Thanks for the explanation. |
