Date/Time: Sat, 18 May 2024 14:44:53 +0000
LMAX -BIDASK
View Count: 636
[2018-10-24 18:05:40] |
ILIM KIRGIZ - Posts: 187 |
I use LMAX for FX trading. I read this Sierra Chart Real Time and Historical Forex and CFD Data Service and Data Recording Modes and decided to use FX pairs at this recording format. Example USDMXN-BIDASK. I understand that both bid and ask prices are recorded to my computer harddrive in this manner. But I'm confused when I look at the chart as It has different values then regular symbol (USDMXN). Could you please clarify what I'm exactly seeing on the screen when I set the symbol as USDMXN-BIDASK? Thanks. |
[2018-10-24 19:05:00] |
Normally what you would see when using USDMXN is the bid and ask average prices only.
[2018-10-25 10:29:36] |
Thanks for the prompt reply. I read that I'm seeing average prices only when I set it to USDMXN. My question was not this. I made a test for comparison purposes. Please see the attached screenshot. Above you will see data recording is set to USDTRY. Below it is set to USDTRY-BIDASK. 1. Bar colors are behaving strange. Why? 2. What am I seeing exactly when I set it to USDTRY-BIDASK? Thanks. |
Attachment Deleted. Capture.JPG / V - Attached On 2018-10-25 10:29:29 UTC - Size: 88.29 KB - 275 views |
[2018-10-25 17:43:31] |
1. We do not know what this means. 2. You see chart bars which represent the highest Ask price and the lowest Bid price during the formation of the chart bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
