Date/Time: Mon, 06 May 2024 12:56:11 +0000
Crosshair
View Count: 1968
[2013-10-30 15:46:52] |
gmorgan111 - Posts: 121 |
When I have the pointer set to the arrow, the arrow is always a white color. When I select the crosshair the little cross is always a dark gray. My chart background is dark gray and therefore I cannot see the crosshair. When I click the chart with the crosshair then the verticle lines from the little cross go out across the chart. Those lines I can change the color in the tool settings chart values tab. When I change the color the lines it still does not change the color of the little cross. Can you tell me how to change the color of the little crosshair and also at the same time the arrow. Thanks |
[2013-10-30 17:58:41] |
This is controlled through the Mouse pointer settings in the Windows Control panel.
