Date/Time: Sat, 18 May 2024 12:40:26 +0000
Alerts on time and sales
View Count: 1282
[2018-10-22 23:39:04] |
abn2609 - Posts: 15 |
T&S window > settings > highlight & alert... So when my alerts trigger, the alert rings multiple times. You say this issue was fixed. I'm telling you it's not. This is exactly the same issue as the previous thread, which you locked without resolving it. Date Time Of Last Edit: 2018-10-23 17:31:08
[2018-10-23 17:31:48] |
We need to get the chart which the Time and Sales window is for to test this. Follow these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-24 05:29:32] |
Trade Activity Log: File read result: 103 records inserted. 0 fill records inserted. 0 records filtered. | 2018-10-24 10:30:03 Trade Activity Log: File date-time limits: Sim records date-time limit is 2018-10-08 00:00:00. Non-sim records date-time limit is 2018-07-22 00:00:00. Non-sim fill record date-time limit is 2017-10-23 00:00:00. | 2018-10-24 10:30:03 |
[2018-10-24 06:05:21] |
This is not what was requested according to the documentation. Your web browser did not scroll to the correct position. This is the relevant documentation: Support Board Posting Information: Providing Chartbook with Only a Single Chart (Providing Chartbook with Only a Single Chart) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-24 23:53:25
[2018-10-25 01:04:08] |
File attached
[2018-10-31 11:59:59] |
Hi, Has there been any progress made on this? Thanks |
[2018-10-31 15:25:53] |
Yes, this has been resolved in the most recent build - 1833. You can upgrade using these instructions: Software Download: Fast Update
