Date/Time: Sat, 04 May 2024 17:05:31 +0000
[User Discussion] - global cursor
View Count: 1363
[2013-10-30 13:30:36] |
User16114 - Posts: 153 |
assuming four charts are open is it possible to have the global cursor active on 3 and not on one? I'd like to have the global cursor not active on a daily chart but active on intraday charts. I apologize in advance if this is in your documentation somewhere - I can't find it. |
[2013-10-30 16:29:16] |
above post is assuming "Chart Values/Crosshair" and "Global Cursor On" are both active in "Tools" dropdown menu.
[2013-10-30 18:01:35] |
No. This is not supported.
