Date/Time: Fri, 03 May 2024 07:30:16 +0000
Open & Close Markers on Price Volume Bars
View Count: 920
[2018-10-22 14:39:52] |
User24187 - Posts: 54 |
I am using a color study with Price Volume Bars. As such, I cannot use the candlestick bar option to show open and close. Would it be possible to have an open and close marker on the OHLC Price Volume Bars?
[2018-10-22 18:09:47] |
User750920 - Posts: 274 |
I don't know if I understand you correctly - are you the price volume bars the Numbered Bars Study?
[2018-10-22 18:21:12] |
No I am using the 'Graph Draw Type' as Price Volume Bars. But the open and close markers do not appear when the OHLC option is chosen for Price Volume Bars.
[2018-10-23 17:33:07] |
SC Engineering please advise
[2018-10-23 17:36:43] |
Would it be possible to have an open and close marker on the OHLC Price Volume Bars? This is not supported and it is not something we would be able to support anytime soon.
