Date/Time: Sat, 04 May 2024 14:59:08 +0000
TPO chart RTH and ETH value areas set up as different colors...
View Count: 1406
[2018-10-20 18:50:49] |
User629089 - Posts: 93 |
Hi, I have TPO charts set up for the ETH session separated from the RTH to show the overnight activity. Under Settings and Inputs for the TPO profile, I have the "Highlight TPO Value Area" and "Highlight TPO POC" set to yes. Under subgraphs, the "TPO Letter/Block Color (SG13)" has two separate color options that show up as one for RTH and the other for ETH. Two lines lower, the "Value Area Color (SG15)" has only one color and therefore not allowing me to have a different value area color for RTH and ETH. I've gone through the support documentation but wondering if I'm missing something? I'd like to have this set up with different colors for the value areas when I merge each subsequent days data into a weekly profile. Can you help? Thanks... |
[2018-10-21 08:51:55] |
We have to look into this and add support for that.
