Date/Time: Mon, 06 May 2024 04:40:04 +0000
How to apply a profile on both studies
View Count: 567
[2018-10-19 18:35:57] |
Dan the Man - Posts: 82 |
I have a chart with the ES on the 1st Chart region and the NISS-SP on the the 2nd Chart region I would like to be able to apply a volume profile on the ES and also on the NISS-SP but only the 1st Chart region with display the volume profile. How can I apply separate volume profile to both chart regions. Regards, Daniel |
ES and NISS-SP.jpg / V - Attached On 2018-10-19 18:33:47 UTC - Size: 282.77 KB - 236 views Attachment Deleted. |
[2018-10-19 19:43:00] |
This is not supported. The Add Additional Study does not support the use of the Volume by Price study. You will need to use a separate chart for that symbol.
