Date/Time: Sun, 28 Apr 2024 08:34:10 +0000
Number of Trades Per Bar is not updating correctly in real time
View Count: 553
[2018-10-19 22:11:34] |
This must be due to the particular data feed being used. It does not sound as though there would be a solution to it other than using a different data feed but then again this is not something we normally hear about. Refer to: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
