Date/Time: Mon, 13 May 2024 17:30:33 +0000
Probleme with close indicator of the Number Bar
View Count: 506
[2018-10-19 09:40:29] |
User210074 - Posts: 63 |
Hello, I do not understand what's going on!!! In the "NUMBERS BAR" program, I use the "Open and Close Style Maker" function to display the closing price of a bar. It works very well all the time, except today. As you can see in the picture I have two Close on a Bar. I thought a bug in the graph. I did a reload the chart, but no change. I close and restart SIERRACHART, no change. I restart the computer, it's the same, there is no change. Can you tell me what to do to fix this bug ? Date Time Of Last Edit: 2018-10-19 09:41:39
Capture1.PNG / V - Attached On 2018-10-19 09:39:49 UTC - Size: 58.54 KB - 204 views |
[2018-10-19 10:32:59] |
Do you know why this is the last trade price?: 1.14978 The last digit should either be a 5 or a 0 but it is 8. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
