Date/Time: Fri, 10 May 2024 01:44:12 +0000
Tool Settings
View Count: 555
[2018-10-19 07:52:02] |
nicktrader - Posts: 665 |
My "Tool Settings" says "After... use Change to ==>> Chart Values". If I use "Custom Text..." (Buttons are placed in my Control Bar) there is no change. Custom Text is still on. Is that correct? |
[2018-10-19 08:04:54] |
Apparently so. We would have to check the implementation but that does seem to make sense.
[2018-10-19 08:36:10] |
I use "Custom Text" as a kind of marker. Behind each "Custom Text" No. is a small text such as "HH", "LL". So far I have always used the tool "Type Text" and created several TCs. With the "Custom Text" I promised myself a further relief. But if the cursor doesn't switch, it's no improvement from my point of view. |
