Date/Time: Fri, 03 May 2024 23:08:44 +0000
Chart Drawings
View Count: 609
[2018-10-18 20:37:58] |
User41512 - Posts: 58 |
I have noticed recently that when using chart drawings, (Say an arrow for example), when i try to move or amend it I often have to click it 4/5/6 times before it will eventually be selected. I tried upgrading to Version 1815 but i still have the same issue. Occasionally it will select first time, but more often i get the above issue. I have tried selecting whilst using the pointer tool & the cross-hair, and also tried left & right clicking to make the selection. Attached is an example. http://www.sierrachart.com/image.php?Image=1539894922422.png Thks |
[2018-10-18 23:03:08] |
We do see a continued problem with this with lines that are nearly vertical. We will implement a solution . Just give us a couple of days.
[2018-10-19 23:24:42] |
This is resolved in version 1825.
