Date/Time: Fri, 10 May 2024 01:57:13 +0000
Pin Entry Order to Subgraph
View Count: 574
[2018-10-18 19:09:41] |
User993067 - Posts: 142 |
Is it possible to pin an entry order (limit entry with brackets and stops...essentially a trade window configuration file)to a subgraph on trade dom or chart? Say I want to place a limit at or near the VWAP or any subgraph can I affix a custom control bar radio button that would place the limit order and adjust the order to the subgraph until filled and then the trade configuration takes over. Trader could assign multiple control bar buttons for different entries, subgraphs, etc. Sort of semi-automated trading (the entry is controlled) with the ability to manually override when trader sees fit. ( can wait until trade configuration plays out or exit, cancel pending entry etc. Thanks. |
[2018-10-18 22:08:00] |
For this you really need to use the Spreadsheet System for Trading study: Spreadsheet Systems, Alerts and Automated Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-18 22:08:12
