Date/Time: Fri, 10 May 2024 14:09:44 +0000
Type of Bracket order
View Count: 602
[2018-10-18 13:45:22] |
User154308 - Posts: 7 |
there are numerous choices... what I am looking for is the following enter order and two orders are entered... stop at X, Limit exit at X (I know how to set that) .... then if moves X number of ticks go to Break even on the stop. What option does that please |
[2018-10-18 17:40:59] |
This is documented here: Attached Orders: Move to Breakeven for Stop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
