Date/Time: Fri, 10 May 2024 13:06:45 +0000
not selecting the volume profile with crosshair
View Count: 479
[2018-10-18 06:06:11] |
User884550 - Posts: 149 |
when i have volume profiles drawings that include quite a few days, then profile rectangle is so big, that I cant just click into it with the crosshair, to see prices etc, click automatically selects the profile, which causes too many accidental changes in the profiles any way to avoid selecting the composite profiles when clicking into them? |
[2018-10-18 17:49:38] |
You need to enable Global Settings >> Tool Settings >>Select Drawn Volume Profile by Outline Only.
