Date/Time: Tue, 07 May 2024 00:25:16 +0000
replicating entire databse except for session times.
View Count: 1171
[2013-10-29 20:27:55] |
gabby alindogan - Posts: 49 |
Hi I currently have a chartbook with about 30 fx pairs using the FXCM forex data. I set the session times from 00:00:00 to 23:59:59. I was wondering if I could replicate the tickers, studies, charts,and all the other objects onto another DB except having session times from 17:15:00 to 17:00:00 to replicate IB's trading hours. I still would like to keep FxCM as the data source for the 2nd DB. Thanks. |
[2013-10-30 17:20:13] |
You can make a copy of the Chartbook or you can duplicate charts within the Chartbook. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ChartMenu.html http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html You can set up the Session Times for the symbols in Global Symbol Settings: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php Once those are set up, you can go to each chart and then use Chart >> Chart Settings >> Apply Global Symbol Settings to set the session times. Make sure you have enabled the option as explained in the documentation to apply the session times to Intraday charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
