Date/Time: Fri, 03 May 2024 20:56:53 +0000
ACSIL program to display text table in a chart region
View Count: 1491
[2018-10-18 00:39:57] |
Andy Sureway - Posts: 93 |
Hello, I am wondering are there existing examples of displaying text tables in a chart region. The region just consists of aligned values, one column for each bar? And there is no drawing otherwise? Thanks a lot! Best, |
[2018-10-20 03:01:21] |
bradh - Posts: 854 |
Search studies7.cpp for DRAWING_TEXT.
[2018-10-20 04:50:34] |
That is not the right way to do it. We are going to put together documentation for the proper way to do this.
[2018-10-24 08:07:56] |
The documentation should be out tomorrow.
[2018-10-24 20:43:49] |
John - SC Support - Posts: 31360 |
The documentation for the Numeric Information Table Graph Draw Type ACSIL features is now available. You will find it starting here: ACSIL Interface Members - sc.Subgraph Array: Numeric Information Table Graph Draw Type At the bottom of this section there is a reference to an example which is found in studies8.cpp and is called scsf_NumericInformationGraphDrawTypeExample For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-24 21:12:31] |
Thank you Team Sierra for this. I think you forgot to include a screenshot.
[2018-10-24 21:17:07] |
Yes, we did. Thank you for the reminder.
[2018-10-24 22:01:02] |
Thank for your efforts to make it happen, Team Sierra!
