Date/Time: Sun, 28 Apr 2024 12:16:54 +0000
Graphic Settings for chart not
View Count: 574
[2018-10-17 21:29:37] |
jaxscott - Posts: 57 |
I have to reset the color of the Chart Values: Color of the Price and Time Boxes every time I open up this chartbook. It doesn't "stick" like other selections. It seems like this is the only option that exhibits this behavior. Specifically, setting from the default black to my selection of white. This behavior is consistent.
[2018-10-17 22:14:11] |
Does a chart have a white or light background? That might be the cause of this. It is automatically getting corrected.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-17 22:14:22
[2018-10-17 22:26:28] |
It's a black background.
[2018-10-18 10:38:47] |
We do see this issue when a chart is using its own Graphics Settings. This will be resolved in the next release.
