Date/Time: Mon, 13 May 2024 04:00:04 +0000
formation process Range Per Bar - Standard vs. Open=Close
View Count: 1340
[2018-10-17 15:45:31] |
Marc@SC - Posts: 13 |
Hello, I am a bit confused about the formation process of the Range Bars (Open = Close). The screenshot above shows a chart with "Range Per Bar - Standard(in ticks)" (Setting: 4) and below with "Range per Bar - Open = Close" (Setting: 4). The marked bars have different Volumes and POCs. Why does the right red bar only have 4 ticks using "Range Per Bar - Open = Close" compared to other bars in this chart and the "Range Per Bar - Standard(in ticks)" chart? How is the transition from one bar to the next? Thanks Date Time Of Last Edit: 2018-10-17 19:08:30
difference_RangeBar.png / V - Attached On 2018-10-17 17:05:01 UTC - Size: 71.88 KB - 276 views |
[2018-10-17 20:39:43] |
Refer to the documentation here: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Range Per Bar - Open=Close (in ticks) Duplicate the chart and remove the Numbers Bars study, do you then see the proper range? If so, then it must be a case where the market trading activity gapped by a tick or more. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-17 21:34:14] |
I know the documentation, but there is no explanation for that behavior. left side: I removed all studies in the "Range Per Bar - Standard(in ticks)" (Setting: 4) chart, duplicated the chart and set to "Range per Bar - Open = Close" (Setting: 4). right side: with study Numbers Bars. The result is the same. Date Time Of Last Edit: 2018-10-18 05:34:06
difference_RangeBar 3.png / V - Attached On 2018-10-18 05:32:06 UTC - Size: 116.52 KB - 256 views |
[2018-10-19 14:39:55] |
John - SC Support - Posts: 31555 |
Most likely this is because of New Bar at Session Start. Refer to the documentation here: Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu)
