Date/Time: Mon, 20 May 2024 21:44:51 +0000
[Programming Help] - Tool Values Window.
View Count: 778
[2018-10-16 08:35:49] |
User169391 - Posts: 55 |
I have several studies on my chart, some hidden. I would like to view there values in the Tool values window by scrolling along the chart using the chart values/cross hairs. My problem is the Tool values window is only displaying the values for region 1 and region 2. I have a hidden ADX in region 4, and is not being displayed. I'm guessing this is a simple setting somewhere that i can't find. Thanks for the help |
[2018-10-16 10:49:07] |
You really cannot do this. You have to make the study visible and then hide the individual Subgraphs by setting the Draw Style for them to Ignore.
