Date/Time: Mon, 06 May 2024 05:41:11 +0000
Suggestion for Symbol List
View Count: 786
[2018-10-16 08:23:58] |
User138602 - Posts: 169 |
Hello, i have a symbollist with over 60 symbols attached to a chart. Using the + sign is very helpfull to cycle through this list. Often i need to jump to a specific symbol in the list and go from there. But one cant do that. If i select a symbol from the list via dropdown menu and then press + ,the program jumps back to the next symbol following the symbol in the list when + got pressed the last time. Best Regards |
[2018-10-16 09:02:43] |
You instead need to select the symbol through Chart >> Associated Watch List.
[2018-10-16 09:21:46] |
But we will implement a solution to this in the next release for the Symbol drop-down list on a Control Bar.
[2018-12-13 19:03:55] |
Hello, what happened to the symbol watchlist? I cant use the +/- functionality anymore. Using the control bar watchlist, trying to go through it as it was possible some weeks ago, ends up with symbols not even in this watchlist. Instead it looks like as if i switch through the sc data folder itself. Best Regards |
[2018-12-13 22:00:00] |
Make sure this is enabled: Chart Menu: Only Symbols in Watch List (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-13 22:53:30] |
It sounds like the setting for Chart >> Only Symbols in Watchlist is not selected. Refer to the following: Chart Menu: Only Symbols in Watch List (Chart menu) Also refer to this section for how the Watchlist acts: Changing the Symbol of a Chart: Moving through the Symbols in the Associated Watch List Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
