Date/Time: Fri, 03 May 2024 04:47:57 +0000
cannot connect to data feedd
View Count: 661
[2018-10-15 15:05:20] |
Joel Wisdo1 - Posts: 15 |
I received connection errors all morning. I have sent you a copy of the log. Please help. My internet is working perfectly. But it cannot connect.
[2018-10-15 15:57:48] |
ok are you going to help me? The feed is down and I need to work
[2018-10-15 17:03:07] |
Refer to the Solving Connection Problem section on the Gain Capital / Open ECry Trading Service page here: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ConnectionProblem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
