Date/Time: Thu, 02 May 2024 16:41:25 +0000
Loading Multiple Charts for No reason - Can not delete charts as well
View Count: 622
[2018-10-14 23:12:15] |
User250896 - Posts: 8 |
I could not find a way to fix this problem. Basically if I open a new chart book. > Find symbol > select symbol > load intraday chart > I would have 1 chart > then If I load a study by clicking Analysis > select my Study > 5 charts load up with multiple timeframes. I could not delete it, If I try to delete it it will reload automatically. If I click on another symbol and apply the study again another 5 will load up now I have 10 charts up. Continues to add up until I have over 50 charts up that I can not delete?! please help Date Time Of Last Edit: 2018-10-14 23:26:13
[2018-10-15 01:04:07] |
You must be using a custom study which is opening additional charts. So that study would require them. Contact the developer of that study about it. Or is this one that you developed? You can also hide the charts through Window >> Hide Chart.
[2018-10-15 01:20:05] |
How do I delete 45 of these charts?
[2018-10-15 01:23:53] |
You can just use the standard X button at the top right of the chart window or use File >> Close Active Window when the chart is active. But if they keep reappearing, then you need to remove the Custom Study from the chart or charts which is causing them to be opened.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-15 01:24:04
[2018-10-15 03:27:20] |
thank you got it resolved!
