Date/Time: Sat, 27 Apr 2024 13:42:07 +0000
Any Way To Get Rid Of Multiple Candle Draw Style When Plotting Higher Timeframes?
View Count: 761
[2018-10-13 18:31:22] |
cmet - Posts: 535 |
When you plot candle based studies from higher timeframes, sierrachart defaults to a series of multiple identical candles, one for bar of the lower time frame. Is it possible to simply plot this as one continuous candle that matches the higher timeframe? The multi-column rectangle option is there but the wicks are missing. Attached is an image plotting Cummulative Delta from a different time frame to an execution chart. Date Time Of Last Edit: 2018-10-13 18:33:17
[2018-10-13 21:07:10] |
You really need to be clear about what study you are using. Apparently you are referring to the Study/Price Overlay study. Set Fill Blanks with Last Value to No.
[2018-10-13 22:48:04] |
cmet - Posts: 535 |
It's essentially any of the overlay studies when you plot in candles. Removing fill blanks with last value just creates a narrow candlestick where the spacing has been increased. Thanks though.
