Date/Time: Sat, 04 May 2024 00:33:20 +0000
RANGE IN FUNCTION IS OFFSET BY 2 ROWS
View Count: 588
[2018-10-12 17:17:03] |
User63769 - Posts: 35 |
RANGES ARE OFFSET BY 2 ROWS IN MY FUNCTIONS. PLEASE LOOK AT THE YELLOW HIGHLIGHTS ON MY ATTACHED SCREENSHOT
RANGE IS OFFSET.PNG / V - Attached On 2018-10-12 17:14:12 UTC - Size: 18.98 KB - 269 views Attachment Deleted. |
[2018-10-12 19:24:40] |
There is a mistake in the display of the cell numbers that are being summed, but the underlying calculation is correct. In other words, it is displaying AJ5, but it is really referencing AJ3. If you look at your data you should see a 1 in cell AJ3 and 0 in the rest of the cells from AJ4 to AJ10. We will take care of fixing this display issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
