Date/Time: Fri, 03 May 2024 22:46:10 +0000
Rithmic Connection
View Count: 512
[2018-10-12 17:15:02] |
John Mc - Posts: 32 |
Are you having problems with the Rithmic connection? I have it up and running for other apps but in Sierra it keeps saying "Connecting...". John |
[2018-10-12 17:29:21] |
For a technical explanation of the problem, refer to: https://www.sierrachart.com/SupportBoard.php?PostID=149895#P149895 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
