Date/Time: Sun, 19 May 2024 01:42:31 +0000
trade connecting lines are vertical
View Count: 506
[2018-10-12 15:03:50] |
User40526 - Posts: 166 |
I have read all of the documentation I can find on trade entry and exit lines and cannot determine why mine are plotting vertically on the chart on the exit trade. The time stamp on the entry and exit in the trade log are correct. My computer clock is correct. This just started today when I switched from Rithmic to T4? Thanks |
[2018-10-12 17:08:09] |
This is CTS specific and has been resolved in the latest prerelease. Update to 1821 following the instructions here: Software Download: Fast Update You need to use Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
