Date/Time: Fri, 03 May 2024 19:34:04 +0000
New Trial Stocks Data
View Count: 554
[2018-10-12 13:28:54] |
User371906 - Posts: 141 |
Good morning, I am referring a colleague to try SC trial, does the trial have data for stocks? If not what process must he follow to get this data. Thank you Kindly g |
[2018-10-12 18:16:58] |
Yes there is historical stock data available for many exchanges. What particular exchange did you need data for?
[2018-10-12 18:30:22] |
Thank you for reply. Generally just for equity but could you send me a link were i am may select from differences of exchanges such as if they offer pre market, intra day charts, times, etc. Much appreciated G |
[2018-10-15 17:42:31] |
Have a look at the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service You can find the supported exchanges on that page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
