Date/Time: Tue, 30 Apr 2024 10:15:54 +0000
CrossHair cursor color / width configuration
View Count: 3156
[2018-10-12 05:57:37] |
Meklon - Posts: 217 |
Hello Support, I believe that configuration of thickness and color of the Crosshair cursor was accessed (at least till recently) from either Ctr+Alt+7 shortcut or from GlobalSettings-->Tools Settings (Chart Values tab). But it appears that available configuration options look different now in the 1813 release. Was it move to the different place? Tnx. |
[2018-10-12 18:19:51] |
This is now controlled through the Graphics Settings window: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
