Date/Time: Sun, 05 May 2024 15:32:58 +0000
CQG Data Factory File Format
View Count: 709
[2018-10-11 23:21:49] |
User508193 - Posts: 1 |
Hello, Apologies if this has been covered but I was unable to find it. I am starting a subscription to the CQG Data Factory for downloading historical tick chart data to be used for analysis purposes. The relevant data file will be provided as a ".ts" extension file. They also say that they support 3 different data formats (all variations in ASCII apparently). Can you tell me if SierraChart supports their Data Factory files for importing and if so what format should I request? Thanks much, Kel |
[2018-10-12 00:02:20] |
Yes Sierra Chart has support for the "CQG Time and Sales format". Here is the relevant documentation: Exporting and Importing Intraday Data Files: Import and Load This is a proven and tested import format because we have used it extensively ourselves. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
