Date/Time: Mon, 29 Apr 2024 14:19:40 +0000
question
View Count: 560
[2018-10-11 19:00:30] |
markuz - Posts: 90 |
this is from a client: Also, can you add inputs for price and moving average in the Kiwi ATR Stop? I am familiar with using ohlc4 and Wilders Average. The study would be great, with these additions. |
[2018-10-11 19:26:20] |
This is also something we would not get involved with. That was done by another developer. Users can add this themselves. If you want the source code for the study we can find it.
[2018-10-11 19:28:27] |
understood, thank you!
[2018-10-11 20:35:35] |
Can you please provide the source code? Thanks
[2018-10-12 00:39:59] |
You should be able to find it from this page: User Contributed Advanced Custom Study System Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
