Date/Time: Sat, 04 May 2024 07:25:08 +0000
Price is moving but candlesticks are not
View Count: 645
[2018-10-11 16:45:27] |
User429065 - Posts: 109 |
I get live data on the vertical price scale but the candle is not moving. All my other charts are working properly, it's just with the NYSE TICK. Please advise. http://www.sierrachart.com/image.php?Image=1539276247702.png Date Time Of Last Edit: 2018-10-12 03:29:34
[2018-10-11 18:17:51] |
Most likely it is due to this issue: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.3 - Session Start Time and End Time not Covering Current Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-11 21:27:35] |
They are correct for the NYSE TICK from 830 to 1500 CT. I had it working before the current update and so I reverted back and it still won't work.
[2018-10-11 23:23:58] |
Check again. It may also be the time zone setting. It must be one of the items on this page: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-12 17:50:13] |
Yep you were right, was set on global time zone. Thank you!
