Date/Time: Sat, 04 May 2024 13:28:05 +0000
Backtest and Chartbooks
View Count: 539
[2018-10-10 23:46:34] |
User459170 - Posts: 262 |
Hi, can I have 2 Chartbooks of the same scrip and take different trades on each while backtesting? For e.g. To backtest E-Mini S&P with System A in Chartbook 1 and System B in Chartbook2 will the trades show separately on each of the chartbooks? Is there someway to do that? This is manual testing using standard replay. Thank you.
Date Time Of Last Edit: 2018-10-10 23:49:49
[2018-10-12 00:36:25] |
This can be a problem and is explained here: Automated Trading Management: Using Multiple Automated Trading Systems at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
