Date/Time: Mon, 29 Apr 2024 15:19:08 +0000
Daily Change Background color on Charts
View Count: 810
[2018-10-10 21:40:25] |
User297050 - Posts: 50 |
The default color on my charts for the daily change is a very bright red that totally covers the change data and I can only see if I get my eyes within 6 inches of the screen. I cannot find how I can change that color to make it more readable. Thanks for the help.
[2018-10-10 22:51:59] |
There are two things you can do. The color settings for this is in the Graphics Settings window: Graphics Settings And you can also prevent the reversing of colors through the Customize Chart Header window: Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-10 22:53:08
