Date/Time: Mon, 29 Apr 2024 07:26:37 +0000
Bitfinex Depth Offers below bids
View Count: 785
[2018-10-10 17:52:45] |
User465507 - Posts: 74 |
Bitfinex order book data isn't display correctly. Increasing the tick increment or leaving as is in units of 0.1 - same result. Files attached: Settings1.png is my settings and that includes the 'market depth combine increment in ticks' set as 1. bids offer intermingled.png is the consolidated depth (increased tick increment) ladderdefault is the default settings with the price display format and tick increment auto-set according tot he data feed. I've noticed there seems to be way less info available & even if I increase the 'maximum market depth levels' to 1000+ it might only show me a few (4-5) quotes from the offers and a significant amount more on the bids. |
Private File Private File Private File |
[2018-10-11 00:41:54] |
We are declining to get involved in this. If Bitfinex is not working well for you, we recommend using BitMex instead: BitMEX Trading Service You can definitely rely that we are not going to help at all with this. That is a substandard data feed with problems. We are also going to be adding data feeds from Binance and Deribit. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-11 00:58:17
[2018-10-11 09:58:18] |
User99735 - Posts: 234 |
Hi, Dont see Deribit in list of service providers in vs 1785. What is ETA for same? Regards Vivek |
[2018-10-11 17:34:37] |
Hopefully should be in about another week.
[2018-10-28 01:46:43] |
D1xVol - Posts: 3 |
Thank you for adding Deribit. Is there any update re the Binance data feed (not trading, just charting)?
[2018-10-28 03:14:32] |
Should be out in about two weeks.
[2018-10-28 06:32:37] |
Hi, Dont see Derbit in vs 1831. When is the ETA? Regards Vivek |
[2018-10-28 22:16:46] |
This is already out. You will see it listed in Find >> Find Symbol >> Deribit For the SC Data-All Services service and the Cryptocurrencies Data service.
