Date/Time: Fri, 03 May 2024 06:11:29 +0000
[Programming Help] - Daily OHLC Single Point - Display Labels
View Count: 663
[2018-10-10 12:14:05] |
User360283 - Posts: 440 |
Please add an option to display the Time of Day for the Hi and Lo Thanks |
[2018-10-10 22:28:38] |
You will need to make this modification yourself. It is not something that we would do. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-10 23:09:22] |
Anyone want to do this and put it into the contributed library?
