Date/Time: Mon, 06 May 2024 09:55:39 +0000
Trade Service Integration Question
View Count: 552
[2018-10-10 01:53:29] |
YMllc - Posts: 36 |
when using the SC data feed, integrated with a trading service, if you are also using that service's front end (CQG Integrated Client for example), will I be able to view net positions / orders on both platforms? Example: using SC data feed, integrated with a CQG live account. Executing outright futures via SC/CQG, and auto-spreader via CQG IC. will I be able to see positions / orders across both platforms, considering it is the same back end and parent trading account? (apologies if that is not something you are able to answer) I have received conflicting information from brokers/clearing firm support on this. Whatever the answer, is that also the case with CTS? Also, are there any brokers actually offering integration with a TT account? That would be my preference, but none I have talked to offer it. |
[2018-10-10 18:23:20] |
when using the SC data feed, integrated with a trading service, if you are also using that service's front end (CQG Integrated Client for example), will I be able to view net positions / orders on both platforms? The answer is yes. The bigger question though is whether two connections to the same account is allowed by CQG.With CTS you will definitely be able to do this. Also, are there any brokers actually offering integration with a TT account? That would be my preference, but none I have talked to offer it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
