Date/Time: Mon, 29 Apr 2024 14:01:48 +0000
Trade Activity Log - Entry & Exit DateTime
View Count: 1581
[2018-10-09 10:13:11] |
User474744 - Posts: 22 |
The 1815 version seems to have several changes to the fields on the trade tab of the trade activity log. I export this data to other programs for automatic manipulation so changes to it are a pain. The date format on the 'Entry DateTime' and 'Exit DateTime' fields are now appending ' BP' and ' EP' respectively. Is this a bug or is this format that is going to be kept? |
[2018-10-09 19:47:11] |
The meaning of those is documented here: Trade Activity Log: Trades Fields Descriptions We can remove those on an export. That is not a problem because we understand the problem it causes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-10 08:47:22] |
What you will find in the next release is a new command on the Edit menu of the Trade Activity Log to enable and disable the display of the Begin Position and End Position indicators on the Trades tab.
[2018-10-10 09:24:20] |
That's appreciated thanks. One other thing, the keyboard shortcut to show the order fills on the chart appears to have stopped working, is that a bug or just me? |
[2018-10-10 09:37:06] |
This has not changed. We tested the assigned keyboard shortcut for Show Order Fills and it enabled and disabled that option without a problem. We recommend reassigning it.
[2018-10-10 10:02:47] |
It works if I re-assign it something other than the default ctrl-shift-o as soon as I assign it back to the default it doesn't work, seems strange. |
[2018-10-10 12:38:05] |
if I assign ctrl-shft-o to another tool it works, but then if I assign ctrl-shft-o back to show order fills it doesn't work, in fact it still shortcuts to the previous tool but doesn't show it in the keyboard shortcuts. a re-install makes no difference.
[2018-10-10 18:26:06] |
We were able to use Control Shift O to enable and disable showing of order fills.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-10 18:26:18
[2022-04-22 16:05:19] |
User318521 - Posts: 45 |
any word on erasing the bp/ep in the date/time column. its ruining my exports
Date Time Of Last Edit: 2022-04-22 16:05:40
[2022-04-22 16:24:57] |
On the Trade Activity Window, make sure there is not a checkmark next to Edit >> Include Begin/End Indicators on Trades List before you export. Refer to the information for this item in this section: Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
