Date/Time: Thu, 16 May 2024 17:01:53 +0000
Chart drawing problems
View Count: 481
[2018-10-08 16:25:14] |
Fabio - Posts: 111 |
Hi there, I've hidden some draw I had on my chart in order to optimize some backtesting I was doing. Buw when I open the "manage chart drawing window" in order to show them back the're shown like they are visible (without the red "x" next to them so to speak) when actually they're not. Like this I cannot recognize which one is shown or not. Another problem I have is related to the right click of the mouse when a chart drawing tool is being used. Before, with a double right click the mouse came back to the default setting (without drawing tool) but with the latest release of sierra, it doesn;t happen anymore (the drawing tool remain active even if I double click). Is it possible to fix those two "problem"? Thanks and kind regards. Fabio. |
[2018-10-08 19:45:55] |
Now you will see the text "Hidden" with the drawing list item on the Manage Chart Drawings window indicating if a drawing is hidden. That particular graphic was removed because it was not large enough for high resolution monitors and we are no longer going to maintain those types of graphics. Double right-click operations are not supported. But you may be interested in this new option: Global Settings >> Tool Settings >> Right-click Exits Current Drawing Tool Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
