Date/Time: Tue, 07 May 2024 09:15:13 +0000
Trade Activity Log
View Count: 473
[2018-10-08 13:59:28] |
User900173 - Posts: 10 |
Thank you for the improvements however there are still some issues. The total fills (daily) is not correct. I should have 10 ad it is showing 4. Also thank you for the flat to flat column in the Trades tab, however, is there anyway to zero out the fill to fill lines and only show one entry of the flat to flat in that column or just bring back the option to see the entire trade tab as with fill to fill or flat to flat. I like the option to switch back and forth. It worked very well. |
[2018-10-08 18:17:00] |
The total fills (daily) is not correct. This is resolved in the latest prerelease.We cannot help with your other question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
