Date/Time: Mon, 06 May 2024 19:32:27 +0000
It's Back lol Text Display for Study Prefix Text is locked
View Count: 1125
[2018-10-08 10:07:39] |
User360283 - Posts: 440 |
Prefix Text is locked on a previous text setting. Can't change this text - it keeps reverting to the former value.. Thanks
[2018-10-12 11:25:29] |
This problem returned in the latest update. v 1815 32-bit It was resolved in a previous version. Study Text Display for Study Prefix Text is LOCKED TO A PREVIOUS VALUE. Therefore adding a new TEXT study is a problem see encl. pic Thanks |
sierra text.PNG / V - Attached On 2018-10-12 11:24:23 UTC - Size: 54.63 KB - 248 views |
[2018-10-14 22:48:08] |
We finally understand the reason for this problem. There was no response earlier because we could not reproduce this and we had looked into this previously and really did not know what the issue was in your case. If you were to reset the study back to default and remove it from the chart and add it again, it will resolve the issue. We are implementing a solution in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-14 22:55:46] |
Thanks. Too many to redo. I will wait for the next release.
