Date/Time: Sat, 04 May 2024 16:19:35 +0000
Swing High and Low
View Count: 1324
[2018-10-07 08:31:58] |
User495158 - Posts: 106 |
Hello! I'm using Swing High and Low study. Is it possible to display only one arrow at swing highs or lows when nearby bars are of the same size? Also, is it possible to display the value of the swing high/ low right above or below the arrow? Please see the attached screenshot. Thanks! |
Swing high low.jpg / V - Attached On 2018-10-07 08:30:09 UTC - Size: 168.47 KB - 344 views |
[2018-10-08 17:30:36] |
Try setting the "Allow Equal High/Low Bars" Input to No if it is not already. Also, is it possible to display the value of the swing high/ low right above or below the arrow? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-08 17:31:25] |
With regards to Is it possible to display only one arrow at swing highs or lows when nearby bars are of the same size? be sure the Input setting for the Equal High/Low Bars is set to No. You will find the documentation here: Swing High and LowWith regards to Also, is it possible to display the value of the swing high/ low right above or below the arrow? , use the following study: Study Subgraph Above/Below Bar as TextYou will need two of these studies, one for the Swing High and another for the Swing Low. You will need to offset the display of the text using the Input Setting Offset in Ticks to move it above/below the arrows. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
