Date/Time: Mon, 06 May 2024 09:13:56 +0000
Prerelease install error message
View Count: 701
[2018-10-05 14:33:17] |
Yoda - Posts: 106 |
Using the SC installer I'm receiving the following message when I try to install the Prerelease Version 1816: Incorrect URL when getting common files list to download If I switch the version to the Current Version, SC installs without any issues. If it helps, I've sent a copy of the install log to support using the "Send Log to Support" feature. |
[2018-10-05 16:29:11] |
samual sprat - Posts: 343 |
Same error here
[2018-10-05 16:30:51] |
John - SC Support - Posts: 31379 |
We are aware of the problem and we are working on fixing it.
[2018-10-05 16:34:37] |
There were some missing files for the update, hence the problem. This has been resolved and if you try to install release 1816, it will install correctly this time.
