Date/Time: Wed, 01 May 2024 13:34:55 +0000
How to change : Hold Limit Attached Orders on Client-Side Until Touched
View Count: 871
[2018-10-03 12:33:56] |
User877753 - Posts: 152 |
Hello, Looks like this option "Hold Limit Attached Orders on Client-Side Until Touched" is the new default : I don't see anymore where to change this option and to send limit order with attached stop. Otherwise, the options for Server Side Bracket Orders is still avalaible, and works fine with Interactive Brokers. Thanks for your help. Regards, JM Interactive Brokers + SC data feed. |
[2018-10-03 17:47:57] |
You need to use this new order type instead: Order Types: Limit if Touched - Client It can be used as an Attached Order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-03 18:05:31] |
Maybe I have not been clear, I'm afraid you missed my point. When I send a limit buy order with a stop attached order, only the limit buy order is transmitted to interactive brokers. The attached stop order is sent to IB only when my initial limit buy order is executed. That's definetely not what I want : I want my stop transmitted to the server in the same time as parent order. This works fine with a bracket order, but not with a stop order. How can I have the child order sent to the server the same time as parent order ? Thanks. |
[2018-10-03 18:31:51] |
When I send a limit buy order with a stop attached order, only the limit buy order is transmitted to interactive brokers. The attached stop order is sent to IB only when my initial limit buy order is executed. Trade Activity Log Analysis: Support Assisted Trade Activity Log Analysis There is no need to make a payment for the analysis. But we need the details requested. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-03 18:53:31] |
I agree, does not make sense... See last trade : sell limit order (not executed as I upload the file) with attached stop, which is client sided. Attached : Trade Activity Log. |
Attachment Deleted. |
[2018-10-03 19:03:54] |
Here is a screenshot of the last trade, from the Trade Activity Log :
Date Time Of Last Edit: 2018-10-03 19:04:32
Private File |
[2018-10-05 02:00:01] |
Okay we understand the problem. When there is only one Attached Order it is not possible for it to be a server-side order attached to the parent. That is not supported. At least we are not aware that Interactive Brokers supports this and even if they did it is not a feature that we would use.
