Date/Time: Mon, 06 May 2024 13:30:12 +0000
Export/Import of Trade Statistics - 1815
View Count: 1281
[2018-10-03 06:20:48] |
Acro - Posts: 436 |
Hi, Wanted to check whether the statistics updating has been completed in the current prerelease. At the moment I note that both the export and import functions inside the Trade Activity Log are grayed out for me and cannot be used. Is this intentional ? Thanks |
[2018-10-03 06:42:28] |
User522029 - Posts: 1 |
Also i'd two issues with SC 1811 and 1815. Title: Trade activity SIM accounts data corruption and non-functioning import. Reference images are shared here: https://imgur.com/a/75tPtxd, and also attached to the post. - Image1: SC1811 : Sim3 : TradeActivityLog : Shows correct fills and times. (PASS) - Sim4 account shows correct stats to. (PASS) Upgrade to 1815 - Image2: SC1815 : Sim3 : TradeActivityLog : Shows in-correct fills, times and stats. Short trades aren't shown properly. (FAIL) - Similar issue with Sim4 account. (FAIL) Selecting a single date 2 Oct 2018. - Export the trading data (from SC1815). (PASS) - Clear data from Trade Activity Log. (PASS) - Import the previously exported data. (FAIL) - Although MessageLog shows 'Importing Trade Activity from ...%PATH%... no activity is imported. (FAIL) Expected behavior: - Trade activity should be similar in both versions SC1811 and SC1815. - User must me able to import previously exported trades from same SC version or another version. If required i can post exported TradeActivityLogExport_2018-10-03. Thanks |
Image1-SC1811-Sim3-2018-10-02_11h08_39.png / V - Attached On 2018-10-03 06:39:05 UTC - Size: 53.67 KB - 288 views Image2-SC1815-Sim3-2018-10-03_01h28_19.png / V - Attached On 2018-10-03 06:39:09 UTC - Size: 53.28 KB - 270 views |
[2018-10-03 08:42:37] |
Upgrade to 1815 - Image2: SC1815 : Sim3 : TradeActivityLog : Shows in-correct fills, times and stats. Short trades aren't shown properly. (FAIL) - Similar issue with Sim4 account. (FAIL) Trade Activity Log: Providing Trade Activity Log File to Support And it is always a good idea to choose a particular symbol at the top of the Trade Activity log rather than using All Symbols. There is a lot of associated complexity when using all symbols and potential for calculation errors due to different currencies and missing Symbol Settings. Selecting a single date 2 Oct 2018. - Export the trading data (from SC1815). (PASS) - Clear data from Trade Activity Log. (PASS) - Import the previously exported data. (FAIL) - Although MessageLog shows 'Importing Trade Activity from ...%PATH%... no activity is imported. (FAIL) User522029, Also your Sierra Chart account is expired. Do you have a non-expired account? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-03 09:11:49
[2018-10-03 08:43:47] |
Wanted to check whether the statistics updating has been completed in the current prerelease. Yes the work has been completed in both the main release and prerelease.At the moment I note that both the export and import functions inside the Trade Activity Log are grayed out for me and cannot be used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-03 08:43:58
